-   Tires and Wheels (https://blazerforum.com/forum/tires-wheels-13/)
-   -   Wheel Backspace (https://blazerforum.com/forum/tires-wheels-13/wheel-backspace-23303/)
fishinhunter12391 Sep 16, 2008 08:56 AM
Wheel Backspace
im going to be buying a set of series 51 wheels within the next week now. I still do not know if i should go with the 3.75 or the 4.5" backspace. does anyone have pictures of a 4x4 blazer/jimmy with 3.75" backspace? thanks
AJBert Sep 17, 2008 02:04 PM
RE: Wheel Backspace
Get the 4.5" bs, your front end will thank you for it more than with 3.75" bs. Unless you really like replacing front end parts, that is.
bad350v8s10tahoe Sep 18, 2008 08:00 PM
RE: Wheel Backspace
I run 3.75 on a 10 inch wide wheel, no rubbing issues
fishinhunter12391 Sep 19, 2008 08:22 AM
RE: Wheel Backspace
bad350v8s10tahoe:do you have a front or rear view picture of your truck?
WolfPack Sep 19, 2008 10:57 AM
RE: Wheel Backspace
I rub 30x10.50s with a 2' BL and the tbar crank+shackles, and I trimmed the fenders. I've got the 4.5' backspacing. 4.5' made my steering start groaning after a few hundred miles. Threw in some lucas steering fix. But with 3.75..it'll be worse. And you'll look like a frog, instead of just a wider stance :D
