-   Tires and Wheels (https://blazerforum.com/forum/tires-wheels-13/)
-   -   Wheel center holes (https://blazerforum.com/forum/tires-wheels-13/wheel-center-holes-90164/)
josh18657 07-04-2015 05:52 PM
Wheel center holes
A set of wheels I picked up have a larger center hole than the stock blazer wheels have. Does this make a difference?
Thanks in advance for any help.
LeWhite 07-04-2015 11:32 PM
Yup it sure does. Search here " hub registered". You probably can get some adapter rings to fill the space, but you will need a way to secure them.
josh18657 07-05-2015 07:38 PM
well that's a bummer but figured it was better to ask then destroy my blazer. Thanks for the reply.
newguy 07-05-2015 08:11 PM
I have a set of Basset racing wheels on my truck, same thing, the center hole is big. But they also have 60 degree lugs. You can still use them, torque the correctly and then recheck them after a 100 miles or so. The lugs are what centers them. They use them on race cars taking corners at higher speeds than you`ll go in a Blazer, Right?
LeWhite 07-05-2015 08:57 PM
Lugs, especially 60* cone seat are not meant to support a vehicle. They are meant to deliver torque, whether accelerating or braking. A 60 * cone roughly decreases the shear strength by 40%. Dont believe me, look it up in the machinerys hand book. ^Please site the sanctioning organization that allows this.
newguy 07-06-2015 05:17 AM
http://www.summitracing.com/search/b...Wheel%20Wheels DOT certified, my mistake they are 45 degree giving more surface area making them have a stronger lock I have almost 10,000 miles on mine with no problem http://www.bassettwheel.com/
Cutting edge design and the never-ending mission of building faster, stronger wheels drives the in-house research and development team at Bassett Racing Wheel. We service the most demanding stock car drivers in the world, and whether it be a dirt short track beadlock wheel or 200 mph super speedway wheel, you can count on Bassett wheels to be the best.
LeWhite 07-06-2015 01:08 PM
Let common sense prevail.
