wheel offset??
are zr2 wheels a different offset or is it the axles that are at a different spacing?
i want to have mine the same width as a zr2 and im probably going aftermarket with the rims so get that spacing that i want. so to have the lip of the rim flush with the body what offset would i need? |
ZR2's have the same backspacing as non-Z's. The track width is about 4" wider on ZR2's, so if you want the same width as a ZR2 get some rims with 4" of backspacing.
Though, you may end up with some rubbing issues up front. |
thank you for the reply.
ok then here is a question... i read in another post that the 2wd is 1.5 backspacing different. but i also read in another thread that someone put 2wd rims on his 4x4 and they stuck out even further. |
Correct, with 2wd wheels they will stick out 1.5" more than the 4wd rims.
