Wheel Questions
Ok, here's my story/question...I used to own a 2004 F-150 SuperCrew. While I had it, I put BF Goodrich tires on size 285/65r18. I now own a 1993 full size blazer (2-door). The tire dealer says that the BF's will fit under the blazer, how-ever I need to find wheels that will fit. He states that I need 18x7 or 18x8 with 6 to 5.5 bolt pattern. So, does Chevrolet make a wheel that will fit (maybe off another model), or does anyone know where I can find some wheels that will not crunch the budget???
Thanks, Scott |
RE: Wheel Questions
So let me get this straight, you kept the old tires from your F-150 and want to put them onto your Blazer.
You should be able to find a set of rims to fit. You'll need to look around at various places online to find the rims that you like, but it shouldn't be too difficult to find 18" rims that will fit your Blazer. |
RE: Wheel Questions
did a search on ebay and came up with some possibilities.
Some rediculously long eBay motors link *EDIT by swartlkk* - editted long link |
RE: Wheel Questions
ORIGINAL: swartlkk So let me get this straight, you kept the old tires from your F-150 and want to put them onto your Blazer. You should be able to find a set of rims to fit. You'll need to look around at various places online to find the rims that you like, but it shouldn't be too difficult to find 18" rims that will fit your Blazer. Yes I kept the old tired and put the factory ones back on. So now I have $1000.00 tires sitting in the garage. Yes I found numerous one's online, but sometimes the info is not very specific enough that I feel comfortable buying unless I was 100% sure they fit. Scott |
RE: Wheel Questions
ORIGINAL: hillbillyinOhio did a search on ebay and came up with some possibilities. Some rediculously long eBay motors link *EDIT by swartlkk* - editted long link Thanks for the link. I have found many online that I like, but some of the discriptions do not make me comfortable enough for an exact fit. Alot of times it will say "blazer", but is that S-10 blazer, full size blazer, etc. Scott |
RE: Wheel Questions
Scott,
Go to the ebay item and click "ask seller question". Ask him the deatils and any questions you have. Get any numbers he can off the rims. If he's a good seller, he'll give you all the info you need. Good luck. |
RE: Wheel Questions
So you have the 6 lug axles on your fullsize right?...
RE: Wheel Questions
ORIGINAL: swartlkk So you have the 6 lug axles on your fullsize right?... |
RE: Wheel Questions
Ok so you are looking for 18" diameter rims with 9" or 10" width and 6 lugs on a 5.5" bolt pattern. So long as it meets these criteria. You should be ok. The backspacing should be somewhere around 4.5"
I have only found a few on various websites and they are not cheap... I haven't found a single steel wheel that is that large. Also, don't hesitate to give a call to some of these online retailers to get more information. |
RE: Wheel Questions
ORIGINAL: swartlkk Ok so you are looking for 18" diameter rims with 9" or 10" width and 6 lugs on a 5.5" bolt pattern. So long as it meets these criteria. You should be ok. The backspacing should be somewhere around 4.5" I have only found a few on various websites and they are not cheap... I haven't found a single steel wheel that is that large. Also, don't hesitate to give a call to some of these online retailers to get more information. Thanks again for your great information. The tire place that I spoke to said that I should stay with 18x8 or 18x7 or the wheels would tend to rub?? Are you saying that I can use the 9" or 10"?? Scott |
RE: Wheel Questions
Considering that a 285/65R18 tire is 11.22" wide, I would not suggest going under 9" rim width.
*EDIT* - do you remember what the rim specs where that you had them on originally? |
RE: Wheel Questions
ORIGINAL: swartlkk Considering that a 285/65R18 tire is 11.22" wide, I would not suggest going under 9" rim width. *EDIT* - do you remember what the rim specs where that you had them on originally? Not sure if I know the actual specs. But the BF's were put onto the factory wheels that came on the F-150 SuperCrew. And, again...based on your statement above...you are suggesting I stay with an 18x9 or more??? Scott |
RE: Wheel Questions
Well, I couldn't find a list for rims wider than 7.5", but on a 7.5" rim, it is not advisable to have a tire with a tread width more than +1.5" or 9" wide. Going with even a +2" width increase for rims 8" or wider would mean that 8" wide rims can take 10" wide tires, 9" - 11", 10" - 12".
I am also getting some conflicting information about stock F150 rims... Some say 18x7.5 and others say 18x9... Do you have a picture of what the rims looked like on that truck? The 18" stock tire size was 275/65R18 so an increase of 10mm on the tread width won't be much different, but it all depends on if it was a stock 7.5" wide rim or 9" wide... Here's a thought. Since you have the tires in your garage, stand one up on its tread, then measure across the beads at the top. This should give you a very rough idea of what width rim it needs. |
