wheel spacers
Old Jun 12, 2006 | 07:32 PM
nails5240's Avatar
nails5240 is an unknown quantity at this point
Default wheel spacers
Once I have the lift put, im hopin to add to the look with having a bit of a wider wheelbase. Instead going out and buying new wheels with different backspacing, I was thinking about just putting in wheel spacers.
What, if any, are the pros and cons of these?
And how much do they cost? I found some on one site for around $200 and some from another one for around $20. So now im just plain confused.
Old Jun 12, 2006 | 08:00 PM
sledneck16's Avatar
sledneck16 is an unknown quantity at this point
Default RE: wheel spacers
pros: -they are damn cheap compared to a new set of wheels
-they are very easy to install
-they look really good (just look at my truck! 1.5's in the front and 2's in the rear)
cons: -your wheel bearings will wear out faster
-you will have to retorque everything twice as many times if you take them off/put them on
-they will most likely give you a vibration if you get the larger ones as they usually arent near perfectly cut--i know i did
bought mine for about 160 with shipping (two separate auctions on ebay from the same seller)
take a look on ebay--they show up quite a bit there--if you're still interested around late august/early september i will most likely have bought new rims and tires--look me up!
[8D]
Old Jun 13, 2006 | 02:29 AM
nails5240's Avatar
Thanks
That doesnt seem too bad. Its probably what Im gonna do.
Ill hopefully be getting them sooner than later, but if I still dont have them by then, I will get in contact with you.
Old Jun 14, 2006 | 12:38 AM
sledneck16's Avatar
alrighty then--good luck!! you know where to find me! [8D]
twistedmetal
Feb 8, 2018 07:04 PM
calee4nyaboy
Nov 20, 2009 11:48 PM
nofear17bmx
Feb 11, 2007 08:59 PM
Bosaliniee
Suspension Tech
Jan 28, 2007 10:23 PM
quontush
Apr 21, 2006 08:27 PM
