Wheel Spacers?
I have a 98 4d 4x4 and I love it but it has always kinda bugged me when I look at it cause it just seems like the wheels are sucked under the the body so far. I would like to add some width to the axles and I have seen these aluminum wheel spacers for about 50 buck a pair. They will supposedly push my wheels out about 2.5 inches. I am really tempted to get them but my question is, Is there any down side to using spacers? what kind of problems am I prone to have if I use them?
have some spacers I don't need if you want to buy them.
Originally Posted by maverick_4x4
(Post 592508)
Moved to: Tires and Wheels
With the money you are going to spend on quality spacers you may as well pick up some new wheels with a little less BS. Then you get pretty new wheels and the wider stance you are looking for. |
I agree, most aftermarket wheels that will fit our trucks have an offset that will push the tires out about 2". Old Camaro wheels work very well too, and can be really cheap.
That or a set of factory 2 wheel drive wheels help get rid of the fat guy with tiny feet look
You might consider just spacers on the rear, also. On the 4x4s, the front axle is wider than the back. Might help the look by evening them up.
Originally Posted by Blazn1
(Post 592531)
I have 1.25 inch spacers just on my rear, makes everything look nice now. picked up a set of 4 spacers from a local yard sale for $25 that a guy ran on his s10 pickup
Ive bean looking at the spacers online too because the rear stance I wanted to even out. I have found a few pairs that had a center ring to make them hub centric. for say 1-1.5" on the rear is this something i should worry about?
