Wheel spacing
Are the wheels spaced differently on the front axle verses the rear axle? My front goes to the edge of my fender and the rear ones are still inside the fender. Just figured i would ask and if they are different what size spacer would i need for the rear to match them out.
wheels are the same everywhere, rear axle is narrower by design.
I believe it's 1.25" spacers, do some searching to double check. It's been discussed many, many times |
Thanks. I was just having a hard time finding it on here. I will keep looking or just grab a tape measure and go measure.
I used 1.25" spacers on the rear of mine cause that's what I measured on the driveway, but lots of people use 1.5" spacers. The difference is only a 1/4" per side so I doubt you'd really notice it.
I am going to go with the 1.25" spacers as well. found a set on line that are hub centric so will get them on payday. Thanks everyone.
