Wheels
If i were 2 buy new wheels(rims) for my 95 what size should i look for.
RE: Wheels
It looks like you have a 4x4 so you would need to look for a 15" rim with a 5 on 4.75" bolt pattern with backspacing between 5" and 6". The stock rim has 6". If you get a rim with 5" of backspacing, it means that the rim and tire would sit 1" further out from the truck. This isnt a problem unless you are trying to run bigger tires than stock and havent lifted the truck since the tire has a bigger chance of hitting the fenders. Hope this helps you out. If you got any more questions post up.
RE: Wheels
Nope no lift yet it's pretty much a stock blazer and thanks for the help.
