Wheels for 97 2 door
Ya i Was goin to put the black rock krawler wheel on my blazer but the guy at big o said that if i did that i could only do stock tire size(235). He said for wheels to not rub i would have to get a positive offset wheel. Is that true? Any help would be great! thanks ryan
[IMG]local://upfiles/9002/708E7F8E2312489080BB7EF202776F8F.jpg[/IMG] |
RE: Wheels for 97 2 door
on stock wheels you should be able to get 30x9.5x15 which is slightly larger than the stock 235/75r15's.
youre truck appears to be a 4WD but im not positive. if it is 4WD, then you want to find wheels with 6" of backspacing (ie. very high postive offset, like 50mm) in order for them to not rub. this is where the tough part comes in. out of all the black rock crawler-style wheels i have ever seen, they are almost all 4.5" or less backspacing. if you were to run those wheels (4.5" b.s.) with stock tires, you still may run into some rubbing issues up front. unless you find some wheels with 6" backspacing, 235/75r15 is probably the largest you would want to run |
THats what i thought but i wanted to ask and make sure. It is a 4X4, do you think doing shackles and crankin up the torsion bars would allow me run rock krawler's witha bigger tire?
yeah, depending on the exact specs of the wheel and how high you crank the t-bars, you should be able to fit a slightly larger tire with those wheels
Great thanks! Do you know of any black wheels that would look good and not to ricer, with the right amout of backspace?
i have never seen any with 6" backspacing but you might wanna check out www.summitracing.comor www.4wheelparts.comand see if they have anything
EDIT: i took the extra "e" out of the 4wheelparts link... |
Sweet thanks! il see what they have.
ya
ORIGINAL: otnietdehoooo i have never seen any with 6" backspacing but you might wanna check out www.summitracing.comor www.4wheeelparts.comand see if they have anything |
ORIGINAL: TripleBlackBlazer ORIGINAL: otnietdehoooo i have never seen any with 6" backspacing but you might wanna check out www.summitracing.comor www.4wheelparts.comand see if they have anything |
