Will 235/75/R15 fit my stock 98 blazer?
Sorry to ask this guys as I know its been asked but I see some people say stuff about cutting fenders, etc and some say not needed. Thanks alot.
Yes it will. It was a stock option on the 98+ Blazers, not sure about pre 98.
my '92 Jimmy & my '84 Blazer both came with 235/75/R15's from the factory. but my '91 4 door Blazer came with 215/70/R15's on it, weird. the only reason i can thik of is that the '91 was 2WD.
simple answer: yes
You didn't mention 2wd or 4wd. 4x4's that size as an option. Second gen 2wd's had 235/70/15's as the only tire size. It will still fit though.
yup I run them on my Blazer with no rubbing or any issues
i also forgot to mention, whatever tires you end up buying, get the "LT" version. as in, "LT235/75/R15", not the "P235/75R15". since the LT's have more sidewall plys, they'll give you better handling (more stability) & better load capacity. some people will argue that they're a harsher ride (which is BS, IMO), and i'm not gonna go into the whole arguement about "buying a car if you want a silky smooth ride".
Thanks guys.....tires on now with zero rubbing.
i know is an old Thread but my question is. I have 235/70 r15 on my truck now i know the 75 will fit but will it mess up the speedometer and the odometer?
