will these work
Tracker ZR2 Rims - eBay.com
will they work on a non zr2 and just a regular 2 wd blazer they look pretty cool and idk if they would look cool on a blazer since its a traker rim but if i found a set.i would be possiple looking to buy *EDIT by swartlkk* - Fixed long link. |
RE: will these work
The ZR2 they are referring to is the ZR2 package offered on the Trackers, not on the Blazers. I doubt the bolt pattern is the same and they are 15x6 rims. Stock Blazer rims are 15x7. Do you really want to go to a skinnier rim?
EDIT: And please use the https://blazerforum.com/rteimages/hyperlink.gif button to add a hyperlink to text in your post. If you need help with this, don't hesitate to PM any of the moderators/administrators. |
RE: will these work
oh know i didint know about the link think. well i dont know proppley would i like the pepboys m/t they have by copper i like my m/t tall and skinny not wide. so if i was to get a skinny m/t a skinnyer rim would hurt it would it. i just wasint sure about backspaceing and such.
RE: will these work
Judging by the hub diameter, I'm going to say that they won't work.
*EDIT* - A quick google search and I found that the 2003 Tracker rims are 5 on 5.5 (ours are 5 on 4.75) bolt pattern and most likely will be only 4" of back spacing. |
RE: will these work
so no go?
RE: will these work
They will not fit, period.
