will they fit??...
Would i be able to fit 18" and /or 20" rims on my 96 jimmy with a beltech 3/3 drop (i know i can bolt pattern wise but size wise)??.... if so what tire sizes would u recomend?.....
RE: will they fit??...
20"s may be pushing it a little. but the 18's should fit. i would try to match the overall hight of your current tires to the now ones. if you have some rubbing now go a little smaller. heres a link to play around with possible tire sizes that would work.
http://www.1010tires.com/TireSizeCalculator.asp enter your current size and then try different sizes until you get a size that is the same or close hope this helps |
ya it does thnx.. i was talkin to some other guys on another forum site .. and i think im gunna go with 18"x8.5 ADR rims with a 35 mm offset with 255 or 245 / 45 / 18 wheels....
