Would these rims fit ?
Hey y'all I have a 4 door 93 S10 blazer 4x4 and I wanted to see if these rims would fit on my truck does anyone know they came off a maro ss and they have a bolt pattern of 5x120 ?https://cimg7.ibsrv.net/gimg/blazerf...4bf51ca130.jpgI want these rims but don't know if they will fit in my truck
What did they come off of? Our trucks are 5×4.75(5×120.65) lug pattern.
5 bolt chevy rims, they should, but why?
Originally Posted by newguy
(Post 687370)
Originally Posted by chevyriders
(Post 687369)
(Post 687372)
The majority of modern 5 bolt chevy wheels are not 5x4.75. Other than s series, f body, g body and corvettes up thru c6 are the only others that are the same lug pattern.
Yeah the newer style camaros are 5x120. Our trucks are technically 5x120.65. That .65mm- while not a lot- is enough to put significant linear pressure on the lugs when tightened. That can and has led to people shearing lugs.
No problem newguy, glad to pass the info along. |
(Post 687378)
No problem newguy, glad to pass the info along. it is possible what size spacers ? |
You could use adapters/spacers, 1.25" is the minimum you can run without having to trim your lugs, so that's what I would go with. Depending on how tall/ wide the tires are you could end up with your tires rubbing the fenders.
