Would these wheels fit the blaze?
I was wondering if these wheels would fit my blaze and do you think they would look good with a black powdercoat?
Click here for Camaro Wheels..................................... |
I can't imagine that they would change the bolt pattern, so they would probably fit.
Originally Posted by Thogert
(Post 473151)
Shmexy.
(Post 473153)
Shmexy.
Give me a minute and I'll try it out. I'm not promising much tho.
(Post 473155)
Arrgh, I can't do something that complicated. I just don't have the skills for something like that. Mabey someone else can do it for you. :icon_shrug: Sorry.
Those are my wheels! They aren't from a '96, though. They were only available on the Camaro SS from 2000-2001. $100 is a STEAL! You will need a pretty wide tire to correctly fit on a 9" wheel. I have 255s and I probably should have gone with a 265 or 275 but I haven't had any issues with the 255s. The tread patch is a little narrower than the actual wheel width and they had some trouble seating the tire. Are you looking to put A/T tires on it or? 255/70/17 is pretty dang close to a 31" tire so be prepared to cut and tweak the tbars depending on the condition of your suspension. Check out my "It's About That Time" build thread for more info if you'd like.
https://blazerforum.com/forum/builds...ut-time-46904/ http://i160.photobucket.com/albums/t...h_486d82a1.jpg ^Pre-lift |
Originally Posted by TripleBlackBlazer
(Post 473184)
https://blazerforum.com/forum/builds...ut-time-46904/ http://i160.photobucket.com/albums/t...h_486d82a1.jpg ^Pre-lift Hopefully some A/T's but not really sure right now. If it wasn't A/T's then it would be the dreadfully boring all-seasons lol. |
| All times are GMT -5. The time now is 03:00 PM. |
