ZR2 Tire Questions
What are some good choices for tires for a 2004 ZR2 Blazer, it has 265/75/R15 on it right now, looking for an aggressive tire that can use off road but primarily will be used on the highway. I am thinking of getting bf goodrich all terrain ta's, just open to other suggestions or comparable sizes like 33/10.5/R15.
31X10.5's is what came stock on ZR2s until late in the production run and then the Blazers started getting the 265/75s. As stated, BFG A/T KOs are pretty much the standard for the best on/offroad tire out there, though you might want to look at the Cooper ST. It was a toss up on which one I wanted to go with but I could only get 33X10.5s in the BFGs (yes, I have a body lift, shackles and tbar tweak).
Cool, the BFGs and Cooper are the main ones I was considering, the size thing just threw me off, cause they only come in 31s, don't want to have reset my speedometer or anything, and the blazer is a completely stock 2004, just got it, and basically, tires is about all i can afford to do to it, maybe cold air intake or least a better air filter not sure, thanks I will look at both tires and see what I can do.
