05 GMC Envoy XUV Rear Susp Sagging
I need help guys. Just bought this 05 XUV about 6 months ago and the rear suspension has failed. The car is sitting very low.
How do I troubleshoot this problem? Anybody have any experience with this air suspension? The aux air switch flashes once, then a long pause, then one flash. What does this mean? Scott |
Your problem is likely with the airbag itself and not with the compressor or lines. I have heard of a lot of failures with the bags.
Hey Kyle, you know, the darn compressor doesn't even try to pump air as if its fried out. I'm wondering what that single flash long pause single flash....is all about. I'm going to drop the spare tomorrow and start the troubleshooting.
And yes, I am reading alot of issues with this system as well. This truck is starting to make me mad. Last week it blew a water pump with no warning what so ever. |
The compressor will only try to fill the bags for so long before it will shut down. If the compressor just never comes on, then either the fuse is blown, or the compressor itself is bad.
Where are you looking to see this light you speak of? If you do end up needing a new compressor, CLICK HERE - pricey I know, but... |
Many of the XUV models have an auxiliary air pump, Works off the same compressor at the air bags. Anyways, its that switch that is supposed to flash trouble codes.....so I have ready anyways. There's not a lot of information around so I'm struggling.
When you turn the car on, the compressor should go off until suspension is leveled off. Read somewhere that my single flash is an EPROM issue....i'm not buying that. Scott |
I am pretty sure that all of the GMT360/370 platform vehicles optioned with the automatically leveling suspension have the air outlet in the back. I'll see what info I can find in my FSM.
thank you Kyle. I appreciate that.
Read allot of material on this subject over the weekend. I will wait to start tearing the system apart until I get some guidance... Couple of folks indicated they parked the car on a curb to get it extremely un-level and had the system kick in. Another jacked the car up high from the read and did the same thing. Makes no sense to me unless the right and left leveling sensors are not sensitive enough or "sticky"..... not sure how they work. Ha ha, I also found a coil over system that replaces the air suspension. If this thing is going to be troublesome, I may just bite the bullet and convert. Scott |
Sounds like a no brainer.See below.
DTC 001 Circuit Description The air suspension compressor assembly monitors the calibrations in the electrically erasable programmable read-only memory (EEPROM). The module also monitors the compressor, solenoids and internal wiring for faults. DTC Descriptor This diagnostic procedure supports the following DTC: DTC 001 System Disabled Information Stored Conditions for Running the DTC The ignition is ON. Conditions for Setting the DTC The air suspension compressor assembly detects an invalid EPROM checksum or internal component failure Action Taken When the DTC Sets Depending on the condition that set the DTC, some or all functions will be disabled. Conditions for Clearing the DTC The DTC will automatically clear when the condition for setting the DTC is removed and the ignition has cycled from on to off to on. Diagnostic Aids The air suspension compressor assembly will set a DTC 001 when any of these conditions are present: • A checksum error in EEPROM is present. • The compressor is shorted or open. • The compressor solenoids are shorted or open. Action Yes No 1 Did you perform the Diagnostic System Check - Vehicle? Go to Step 2 Go to Diagnostic System Check - Vehicle 2 Verify the fault is present. Does the system operate normally? Go to Testing for Intermittent Conditions and Poor Connections Go to Step 3 3
Go to Step 4 Go to Step 5 4 Replace the air suspension compressor assembly. Did you complete the replacement? Go to Step 5 -- 5 Operate the system in order to verify the repair. Did you correct the condition? System OK Go to Diagnostic System Check - Vehicle |
Ken, that is exactly what I was looking for - THANKS. Last night I pulled the compressor assembly out. The one hard line is a bitch to get out. Ended up just prying out. Not sure it will seal back up when I hook it back up. Anyways, there are 4 hoses. A left and right line to the bags and then a 3/16" or so rubber hose and the one hard line and those two latter mentioned lines go back to the trunk. I suspect for the accessory functions. There are two connectors and I suspect one for power and the other for the left and right solenoids. I hate to replace that thing without testing it. Its $600. Do you have a wiring schematic that I can put 12 volts across two pins and see if it’s the motor?
1 Attachment(s)
Here is the schematic from my FSM for my '04 Rainier. It should be the same...
| All times are GMT -5. The time now is 03:27 PM. |
