TrailBlazer GMT360/GMT370 (2002-2009) Tech Have a 2002-2009 Trailblazer, Envoy, Bravada or Rainier? Post your general tech questions here.
07 shifter button has no resistance
Old Oct 16, 2016 | 02:04 PM
dtk88's Avatar
dtk88 is on a distinguished road
Exclamation 07 shifter button has no resistance
The button on my shifter has no resistance and i can't get my key out of the ignition. It will shift through all the gears and drives fine but it shifts without having to press the button and it won't let me turn the car all the way off. So i have to disconnect my battery and leave my key in the ignition. Pease help.
Old Oct 16, 2016 | 07:09 PM
This sucks, but of all of the times I have seen this come up, it is a fault within the shifter assembly itself that causes it. The GMT360/370 trucks have their share of ignition switch issues as well, but it is likely that the lever lock button being seized and not activating the park/neutral switch to allow the key to be removed.
Few have had luck removing the assembly and lubricating the moving parts with a bit of disassembly of the shifter itself involved. If you screw something up even more though, the assembly is not cheap and my recommendations would be to try to pull one from a pick-n-pull yard if you have one near you or go with one off eBay (I found at least one from an '07 that was under $100).
Old Nov 11, 2019 | 05:50 PM
DryGulch's Avatar
DryGulch is on a distinguished road
Default Shifter assembly diagram
is there a schematic of the shift lever assmbly whether online or somewhere else? Experiencing same problem with 07 trailblzr.
I want to disassemble clean and reinstall. I have removed console checked Shift Interlock Solenoid. It works when removed away from shift lever.
cbur307736
Sep 15, 2012 08:31 AM
zipmaster
Mar 22, 2011 02:48 PM
racsan
Aug 26, 2010 12:31 AM
bobbo605
Aug 19, 2010 11:59 AM
AntonyJ1214
Jan 3, 2010 10:21 PM
