-   TrailBlazer GMT360/GMT370 (2002-2009) Tech (https://blazerforum.com/forum/trailblazer-gmt360-gmt370-2002-2009-tech-43/)
-   -   2002' Trailblazer LTZ 4x4 Problems. (https://blazerforum.com/forum/trailblazer-gmt360-gmt370-2002-2009-tech-43/2002-trailblazer-ltz-4x4-problems-54264/)
bigbadgrizz660 01-18-2011 12:34 PM
I have an 02' Trailblazer LTZ 4.2vortec. My 4 wheel drive does not work. When I first start it up, all of the lights light up on the 4 wheel drive dial switch then go off. The service 4 wheel drive light is lit up on the dash board. Recentlly I had an transmission line leak, and it appears that some tranny fluid leaked onto the 4 wheel drive solenoid on the front differential. I'm wondering if this is the problem, or could a fuse have gone? Where is the 4 wheel drive fuse, or is there a relay? Any help would be great.
bigbadgrizz660 01-19-2011 08:28 PM
Anyway to OBD read the problem?
swartlkk 01-19-2011 08:32 PM
If the 'service 4wd' light is on, there are stored codes. A full feature scan tool is required to access the TCCM and pull the codes.
Where in NY are you located?
I believe that the transmission line leak is actually part of a recall.
