-   TrailBlazer GMT360/GMT370 (2002-2009) Tech (https://blazerforum.com/forum/trailblazer-gmt360-gmt370-2002-2009-tech-43/)
-   -   Circuit Breakers (https://blazerforum.com/forum/trailblazer-gmt360-gmt370-2002-2009-tech-43/circuit-breakers-46292/)
Willie 06-29-2010 08:55 AM
Circuit Breakers
My wife's 2007 Blazer's power seat is not working. I am looking for the location of the circuit breakers. The fuse box is under the hood, but the manual does not show the location of the circuit breakers. My daughter's 2005 Blazer has them located under the back seat. looking for help.
swartlkk 06-29-2010 09:14 AM
By 'Blazer' I assume you mean Trailblazer. Both should have the inside fuse/relay center under the driver side rear seat.
TRAILB05 04-20-2011 03:59 PM
05 trailblazer driver power seat not working
Do you know what is the fuse on the panel from the driver side rear seat in order to replace. I have the same problem.
swartlkk 04-20-2011 05:41 PM
What more do you need to know? Power is provided to the seats via the 'SEATS' circuit breaker which is located in the rear fuse block located under the rear seat on the driver side as stated already. It is an automatic resetting type circuit breaker. It is rated at 30A. Anything over 30A and the circuit breaker will trip. After it cools off, it will reset. If the current draw is still there, it will trip again. And the cycle continues.
