i live in TX and my A/C is out, HELP!!
i have an 04 trailblazer ext w/ inline 6. about a month ago the rear ac quit working (it stopped blowing air no matter what setting it was on). then a couple days ago my front ac stopped blowing also (no matter which setting it was on) i took it to a shop and had an AC check done and they said that it was the ac blower and resistor. then the price.... $499! so i politly declined their offer.
my question is, could the problem be the blower motor and resistor or something else? and if it is the motor how easy is it to replace? Thank You, bigkeith11 |
It is quite possible that the resistor pack is at fault. I had to do one on my in laws trailblazer not too long ago. No rear A/C, but their fan just quit. It isn't too involving. It is located on the underside of the dash on the passenger side. Remove the hush panel and you'll see it right there. Two screws I believe.
*Moving to GMT360/370 Platform Tech* |
yea, im thinkin thats it. one more thing i was wonderin about, do i have to replace the resistor with the motor? or could it just be the resistor?
Just the resistor. I have yet to see or hear of a blower motor problem with these trucks.
wow, i was surprised. i replace the old resistor and it still didnt work so it was actually the motor. i put the new motor in and the old resistor and it worked ok except for when i put it 5 but it was like that before the motor went out but i put a new resistor in becuause the old one was bound to go out soon.
sooo now that i have fixed the front a/c blower, i now am working on the rear ac unit. i have done some research and i know that the rear a/c is a totaly seperate unit. my problem is, where is the rear ac unit located?? 04 trailblazer ext, inline 6, manual controls. |
*I have combined your two A/C threads since they are both concerning the same subject.*
Originally Posted by rriddle3
(Post 353117)
The auxiliary a/c unit is located in the passenger rear of the vehicle behind the trim.
yea i got a diagram from a user on trailvoy, maybe i can give it to you and you can make a sticky with it??
You can attach it to your post if you'd like by clicking on 'go advanced' and then scrolling down to the attachment section.
| All times are GMT -5. The time now is 03:34 PM. |
