-   TrailBlazer GMT360/GMT370 (2002-2009) Tech (https://blazerforum.com/forum/trailblazer-gmt360-gmt370-2002-2009-tech-43/)
-   -   Please help with replacing valve cover gasket (https://blazerforum.com/forum/trailblazer-gmt360-gmt370-2002-2009-tech-43/please-help-replacing-valve-cover-gasket-47447/)
mladsig 08-01-2010 01:28 PM
I would like a little guidance from all with experience on this. I have a leaking valve cover gasket. I will be replacing my valve cover gasket, plug seals, and intake gasket next weekend on my 2005 Trailblazer 4.2 I6. I have read the recommended procedure and have a few questions. Is it really necessary to discharge and remove the a/c line, or can you find the room to shift the a/c line once you unbolt the hold down line clips and work around it? Any tips or tricks from those with experience doing this job to make my life easier? Thank you in advance, as always to everyone who posts on here. This forum has kept my wallet a little fatter and the car well maintained.
swartlkk 08-01-2010 02:04 PM
Looking at mine, you should be able to flex it up enough after removing the bolt that holds it on the driver side near the alternator. It will be more cumbersome to do, but it beats bleeding the A/C system.
Remember to torque the bolts to 89 INCH POUNDS. Yes, that's not much!
mladsig 08-01-2010 02:25 PM
Thank you very much. I had a feeling that there was a shop technique for that step, to avoid doing this. I figure this will be an all day kind of job. Thank you also for the torque specs. Do you also agree with replacing the intake manifold gasket while I have it removed, made sense to me just to change it out while I had the access.
swartlkk 08-01-2010 02:28 PM
If you don't have to take it apart, I wouldn't bother with it.
mladsig 08-01-2010 02:43 PM
Unfortunately that is the first step in the process is to remove the intake manifold, I wish it was not necessary
swartlkk 08-01-2010 03:27 PM
Yeah, I looked at it again and you cannot get to the bolts along the one side without removing it.
Look at them and see if they are ripped/torn. If not, leave them alone. They only seal air. Not coolant or anything.
mladsig 08-01-2010 05:35 PM
will do thank you again for the help
