TrailBlazer GMT360/GMT370 (2002-2009) Tech Have a 2002-2009 Trailblazer, Envoy, Bravada or Rainier? Post your general tech questions here.
Voltage drops momentarily while coasting
Old Dec 28, 2010 | 09:42 PM
cbenslay's Avatar
cbenslay is an unknown quantity at this point
Default Voltage drops momentarily while coasting
I have a 2005 Trailblazer that has a few issues... My main concern right now is a wierd voltage drop. I can be driving along just fine, but if I let off the gas for a few seconds and "coast" the headlights dim and the volt meter on the dash drops from 15 to 13 momentarily then it returns to normal and the lights come back up. I can repeat this over and over again. The gauge always returns to normal after a split second even if I am still coasting.
Old Dec 29, 2010 | 06:38 AM
*Moving to the GMT360/370 section* - The 2nd Gen Tech section is for 2nd gen s-series vehicles.
This is a known problem with the GMT360/370 vehicles with the 4.2L I6 motor. GM states that the problem is when the vehicle is not run sufficiently long enough when first started for the secondary air injection system to run its startup checks. When the AIR system cannot run its check, the pump will hard (full speed) start whenever the conditions are right for it to run which causes a huge draw on the electrical system. If the startup check is completed, the AIR pump can soft (ramp up speed) start with very little impact on the electrical system. The TSB that GM released on this issue states that the vehicle should be started and left to idle for 30-60 seconds prior to attempting to drive it.
I have not heard of anyone rewiring their alternator for battery reference control as opposed to the PCM control it has stock, but it may be worth a try. Another member just wrote up the details for the 2nd gen s-series trucks yesterday.
Old Dec 29, 2010 | 06:58 AM
cbenslay's Avatar
Thanks! Sorry for posting in the wrong area. It seems this issue IS related to my P0410 & P0455 codes then... Thanks again!
greatwhitenorth
Oct 29, 2013 03:55 PM
Kstrohm
May 14, 2013 04:52 PM
bigzimnh1
Jan 20, 2013 09:31 PM
evlblkwpnz
Feb 6, 2010 05:00 PM
Blazer96
Mar 18, 2006 02:09 AM
