-   Website Problems and Suggestions (https://blazerforum.com/forum/website-problems-suggestions-14/)
-   -   I hope Im posting this in the right spot (https://blazerforum.com/forum/website-problems-suggestions-14/i-hope-im-posting-right-spot-74985/)
1sttimejimmyowner 11-04-2012 10:19 PM
I have some questions on forums rules.For example Im told that I should put all related post in the same thread.
So for example If I start a post about a transmission problem then start another one about a transfer case are not they not different and if not how are they related to being the same?
As fas as I know A topic about a transmission is not the same as a tcase problem am i correct or not?
Rottidog 11-04-2012 11:32 PM
I saw a couple posts by you about your transmission. I thought there were 3 actually.
https://blazerforum.com/forum/engine...nverter-74791/
https://blazerforum.com/forum/2nd-ge...me-luck-74829/
Both could have been combined with the other.
As for your issue with a trans & transfer case - they could both be in the same Engine & Transmission - Blazer Forum - Chevy Blazer Forums because afterall, the transfer case is a little transmission (it transfers power & has gears). (splitting hairs there I know).
But posting a same issue or ways of going about it in different areas (threads) is against rules. Takes some time getting used to them, I know.
1sttimejimmyowner 11-05-2012 10:11 AM
So other than not combining threads
Did I also make some post in the wrong section also?I know that I usualy try to make my post in the 2cnd Gen forums and in the engine and transmission section.Maybe I missed 1 or two.I`ll try and pay more attention to what Im doing.
