Posting troubles
i am new to the forum,and to posting in a forum.my first attempt i accidently double posted and that was the only reply,by e mail,that ihave got from my posts.there is veiws of the posts but no replies.the icons on the post have green check marks ? what am i doing wrong,and how do i delete these posts and start fresh? thank you.
You cannot delete a post after you make it, only Staff can do that. You have posted in three different threads concerning your problem, which I have edited. Please be patient and wait for somebody to reply to your question. Since nobody here gets paid to do this, it's just a matter of time for a reply to come through. When you write a post, being as descriptive as possible about the problem and under what circumstances it occurs will help with getting replies.
to administrator, I joined the Forum just a few days ago {sschwengel}, I'm having trouble trying to find the methods to the forum in general....specifically, where are the instructions or 'how to' listings for doing posting. I've got a question about my 2000 4x4 blazer, 157K miles on it and it won't go into 3rd and 4th gear...it's as if they weren't even there. The engine just revs. How do I post this dilemna onto the forum. I'm sure it is overly simple but I haven't found the trick yet. Thanks in advance for your consideration an/or reply....and just before I send this I've scrolled down for the reply button and down on the left I see posting rules...shouldn't that show up on the initial page right after logging in? ...and I just scrolled up and down the Forum Jump box and the only item I've found is the "Forum Help & Suggestion Center"...and even here it has the choice of "Post Quick Reply" which I'm assuming will send this note to the administrator though the implication is that it may go right on the whole system as my spouting off. thanks again
You must choose the appropriate forum section for your question, then click the https://blazerforum.com/forum/images.../newthread.gif button which will be located at the top of each forum section once you click on them from the main homepage. In your case, the appropriate forum section would be the 2nd Gen S-series (1995-2005) Tech section.
You can also search/browse the forum for past threads that may be similar. The Tech Article (DIY) section has a run down of common problems with the 4L60E transmission (what is in your truck) that may provide additional direction before ever posting a thread. |
