Sig error
when trying to link to an external image for my sig, I get an error saying I have linked 2 images, and can oly link one. Not sure what is generating this, as I am only trying to link to one external image...I am using the same tags to link images as normal. [img]external link, then closed tag. Am I doing anything wrong?
In your user CP go to "Edit Options" and scroll all the way to the bottom. Make sure the "Message Editor Interface" is set to "Enhanced - Full WYSIWYG Editing". See if that helps.
If not, make sure you are using the direct link to the picture. I'm assuming you've uploaded it with a photo hosting site like photobucket? If so..they provide a link with the IMG tags already on it. You should be able to just copy and past that into your sig. |
What is the image you are trying to link to? Looking through your DeviantArt pictures, I believe it is this one:
http://fc08.deviantart.com/fs51/f/20..._DarrenMcD.jpg If that is the case, you have to keep clicking on the image to get to its actual location. In this case, you were attempting to link to: Code:
http://darrenmcd.deviantart.com/art/sig-141512263Code:
http://fc08.deviantart.com/fs51/f/2009/299/9/b/blaz_by_DarrenMcD.jpg |
thanks boss
| All times are GMT -5. The time now is 07:42 PM. |
