1987 Power Window motor
Old 07-05-2013, 06:08 PM
eagle1971's Avatar
eagle1971 is on a distinguished road
Default 1987 Power Window motor
I was wondering if anyone knows if there is a way to test to see if the switch is bad or the motor? Is there a way that maybe I can take a wire from the battery and touch the hot wire on the switch to see if the window goes up and down? If so, which one is it that I need to touch with a hot wire from the battery?
Old 07-06-2013, 04:29 PM
abig84's Avatar
yeah thats how we test them at work using a power probe but you can ghettofy it and just run 2 wires off the battery and check it that way. the way most newer cars work (been a while since i messed with anything from the 80s) is the motor will have 2 wires going to it, positive and negative. but they reverse depending on which way you run the power so if you put + on one side and - on the other the window may go up. no reverse then and the window will go down.
raider1969
03-18-2015 01:20 PM
K5Blazer87
05-28-2014 01:35 PM
knitter0217
03-17-2012 08:00 AM
MudHawg
08-27-2006 02:33 AM
cpaptogo
03-31-2006 12:51 AM
Quick Reply: 1987 Power Window motor
