i have no clue
i have no clue
94 chevy vortex.4x4 changed sending unit in july.pump a year ago,filter last week.i give her gas and she blogs out if i baby the throttle she goes good.i changed my air hoses today and notice the air hose going into the intake collapsed when the truck is in idle.and my 4 wheeld rive wouldnt not click on until i move a lil bit in drive or reverse.then it would go in 4 wheel.the guy at the part store told me that its the air sumthing on the transfer case.its a vacum i guess.would that cause the intake air hose to collapse?also did plugs and wires cap rotor.
RE: i have no clue
What "air hoses" are you talking about? How large are they? Where do they go to? If they are the vacuum hoses, then they should not collapse at an idle. If they do, it is possible that you used the wrong hoses for the application.
RE: i have no clue
THEY GO RIGHT INTO THE INTAKE.next to the dis cap.my friend thinks it should be plastic.
RE: i have no clue 2 what is going on
i changed all my air hoses and put a new t for the hoses and the main hose is tight fit and is still sucking air im lost and confuse help please. would the 4x4 drive sensor since it is a vacum have anything to do with it?i have no check engine light on nothing. why would i have to spray starting fluid to start it everytime
The term 'air hoses' is a bit ambiguous and confusing. You mightpost pictures of the hoses you are talking about so we can tell which ones you are referring to.
Mike
thats under the dc right? i will get pics up this weekend
i must have got bum coil i just changed that in april. why do i have to spray starting fluid to start
If you're spraying starting fluid into it to start, you better check your fuel pressure.
i have good pressure.i changed a spark plug wire it ran good for 2 days and then it started all over again.i have new pump,sending unit,filter,ive dont it all.went to my buddys garage and used his scanner it showed no codes.nothing is wrong
