Vacuum leak around Throttle Shaft (pic)
Old 12-26-2013, 02:09 PM
TennesseeBoy's Avatar
TennesseeBoy is on a distinguished road
Default Vacuum leak around Throttle Shaft (pic)
Made a home-made smoke tester, hooked it to the manifold, and smoke came out of the side of the intake where thr throttle shaft hooks to the throttle cable that opens the throttle butterfly. Could this cause rough idle? How the heck do i fix it? Thanks!
The pic came out sideways, sorry bout that.
Old 12-26-2013, 04:17 PM
Blazin00LT's Avatar
Blazin00LT is on a distinguished road
Does the truck have a maf? If no, most likely it will just idle high. If yes it will cause all kinda weird funky things.
Old 12-26-2013, 04:21 PM
MAF sensors didn't come into play until 1996 with the SCFI motor. Without a MAF sensor, a slight leak around the throttle shaft should have no impact on engine performance and certainly would not cause a rough idle.
Old 12-26-2013, 04:30 PM
No MAF, just MAP (new). I thought(could be wrong) that any vacuum "intake manifold envelope" leak was bad. More air = leaner = more fuel called for by computer = etc. There's lots of threads on TBI throttle shaft vacuum leaks, but cant find any on CPI's.
Old 12-26-2013, 08:26 PM
Pulled the spring and little plastic bushing back and re-smoked. It started coming out all around the throttle plate shaft. Looks like a little red bushing or grommet, but I can't find it on AC Delco or GM Parts. Is it replaceable.
Old 12-26-2013, 08:51 PM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
new upper manifold sadly, junkyard is the choice.
Old 12-26-2013, 09:38 PM
ohsofly's Avatar
Try backyard fixing it with a small O-ring and some lithium grease... Im betting that small bushing is just worn out and a simple backyard fix may get you going again. I dont think that small leak is going to give you a rough idle on OBD1 though sadly.
Old 12-27-2013, 02:34 PM
Are the first gen (obd1) not as sensitive to small vac leaks?
Old 12-28-2013, 05:19 PM
Used the dollar bill and tailpipe trick, never even hinted at sucking it in. Exhaust valve is off the list I hope.
johnnybbik
09-13-2014 07:20 AM
RandyRhoadsFan82
12-05-2013 01:41 PM
Tony H
09-07-2010 07:45 AM
carterx
08-08-2009 08:17 PM
aphexmandelbrot
12-09-2007 01:02 PM
Quick Reply: Vacuum leak around Throttle Shaft (pic)
