1985 4wd actuator cable same as 88 and on ??
Old 10-26-2014, 06:17 PM
justblazin1's Avatar
justblazin1 is on a distinguished road
Default 1985 4wd actuator cable same as 88 and on ??
the dorman part number is a 600-601 for the 4wd actuator cable but it says its for 1988 and up. is that cable the same or is there a differently length one and where do you buy it? cant find it searching on the internet??? thanks
1985 blazer s10 4x4
Old 10-31-2014, 01:40 PM
abig84's Avatar
i would think the one for your truck would be longer. on the older ones they kept it them on the fender, newer trucks they are under the battery so they are closer to the front axle.
Old 11-01-2014, 08:56 AM
on one blazer the vacuum line was to weak so it had a hole or something replaced it now its working . the other was sticky so worked it back and forth
mikepro
08-15-2011 07:03 PM
dheath186
01-16-2011 12:48 PM
AmberRose
08-30-2010 08:58 PM
rknight
07-23-2010 07:19 PM
OhioTrucker090
04-09-2010 12:16 PM
Quick Reply: 1985 4wd actuator cable same as 88 and on ??
