How to read obd1.5 codes
Old Sep 23, 2010 | 12:05 AM
Tortex53's Avatar
Tortex53 is on a distinguished road
Default How to read obd1.5 codes
After doing a lot of research tonight on how to read trouble codes on a 1995 Blazer, I discovered something that might be helpful to everyone. Apparently, it is also possible to read trouble codes using a paper clip on vehicles with "obd1.5" All you have to do is bridge pins 3 & 4 (instead of 1 & 2) on the 16 pin obdII port underneath the dash, and the "Service Engine Soon" light flashes the code. I know that this works, because I was able to pull the codes from mine.
Thanks to Tink and another poster on forums.s-series.org for this information!
Old Sep 24, 2010 | 05:04 PM
Tortex53's Avatar
Is nobody interested in this? I thought it was a big deal when I was able to read the codes in my '95 without a scan tool since everyone on here and my Haynes manual says you have to have one.
Old Sep 28, 2010 | 06:52 PM
As stated in the other thread, this method will work to pull OBD1 type two digit codes from the OBD1.5 specific vehicles, but will not pull the OBD2 (Pxxxx) type codes that these vehicles can also set. For that, a compatible scan tool is required.
Old Feb 24, 2011 | 10:29 AM
ezfrank's Avatar
ezfrank is an unknown quantity at this point
Thanks i was trying to figure this out cause it kept saying error on my scanner. Thanks for the info
Old Feb 24, 2011 | 11:50 AM
cochran07's Avatar
cochran07 is an unknown quantity at this point
My truck has the OBD 1.5 built in late 94 (its a 95 model tho) and I have only had obd2 codes thrown so I havent needed this but its a good thing to know.
Old May 7, 2011 | 11:54 PM
13Blaze420's Avatar
13Blaze420 is on a distinguished road
Cool Thanx
Thank you all for the info, it helped me alot.
kevinph
Feb 25, 2019 09:24 PM
abadinalbany
Apr 16, 2011 11:31 AM
bigjoewebb
Jan 27, 2009 09:36 AM
mikeesho1
Oct 26, 2007 12:31 AM
drperry
Jul 4, 2007 04:25 AM
