highway driving and died
Old 03-19-2017, 06:36 PM
jimdian's Avatar
jimdian is an unknown quantity at this point
Default highway driving and died
Hey, that's what happened to me the other day and now its parked in the ditch. I had a hunch it was the cap and rotor so I gently filed off the bit of corrosion on the rotor and cleaned the points inside rotor. It fired right up and died again five minutes later and now will not start again. These 2 pieces were replaced 1 year ago with a new fuel pump. Fuel pump powers up with key and plenty of pressure at Schrader valve. Was just wondering why it would start again after that fix and how perfect does that copper point on rotor need to be ? Thanks fellas
Old 03-20-2017, 07:17 AM
newguy's Avatar
One it could still be the pump. Needs a minimum of 55psi to open poppers on injectors. 2, buy a new cap and rotor. Acdelco only
Old 03-20-2017, 07:30 AM
jimdian's Avatar
Its getting a cap and rotor tonight. hopefully that gets it out of the ditch and back to somewhere I can work on it.
Old 03-20-2017, 10:21 PM
jimdian's Avatar
mabey it is the pump?, I had buddy listen close for it while I turned the key being outside and windy and all. it is not making the hum that it used to. I put a delco rebuild pump kit from ebay in a year ago and its has been working great ever since.!? idid not even bother with trying new rotor or dis cap.
Old 03-21-2017, 08:41 AM
Tajohns34's Avatar
Did you pressure test it?
Joey1986Z
19
01-08-2014 11:33 AM
mechelle207@yahoo.com
08-18-2011 08:29 AM
Hizapitt
04-24-2010 02:39 PM
Charidy
08-22-2005 02:18 PM
Swblazer
08-15-2005 01:41 AM
Quick Reply: highway driving and died
