95 blazer jerking and no power
Old 12-22-2012, 09:57 PM
Chris Lamp's Avatar
Chris Lamp is on a distinguished road
Unhappy 95 blazer jerking and no power
I have a 98 Blazer with the 4.3L engine that started acting up after a place replaced a blown head gasket. It starts good, runs good for about a couple miles then it just starts jerking and putting and loses power real bad. If you hold the pedal about medium throttle it jerks bad. Let up a little and it slowly gains speed but floor it and it starts to rev up but don't really move a lot faster. it barely makes it up a tall hill by my house. When it acts up, it won't change gears normally and when it does it changes hard. The ses light comes on and when i check it was for the camshaft sensor. when I went to replace it I found out it was unplugged, so i plugged it back in and put a new rotor and cap on while i was at it. still acts up
Old 12-23-2012, 09:59 AM
Chris Lamp's Avatar
Bump!
Old 12-23-2012, 11:46 AM
50lb_cat's Avatar
I would make sure the distributor isn't off a tooth, and since the cam sensor was replaced, a CASE relearn must be done using an appropriate scan tool.
Old 12-23-2012, 02:37 PM
Chris Lamp's Avatar
What would I need to do to tell if my distributor is a tooth off? (sorry this is my second var and this is completely different) Where can I get a scan tool able to do a CASE relearn and how much?
1999BlueMobile
09-01-2014 07:48 PM
Mr Mackey
07-30-2012 03:00 PM
Sparky
07-16-2011 10:14 PM
n.kognitoh
03-12-2011 08:56 PM
moshparts
03-09-2011 02:51 PM
Quick Reply: 95 blazer jerking and no power
