Blazer will start then wont start
Old 09-07-2012, 08:16 PM
FreeTime's Avatar
FreeTime is on a distinguished road
Default Blazer will start then wont start
I have a 1999 blazer with the 4.3 engine and the dang thing will start somedays other times it wont I just put in a fuel pump a few weeks back and it was fine for like 10 days then it started dieing and will not start back up. its like the 4th time it has left us stranded. If u squirt starter fluid in it will start , o I think its something will pump. Any of u guys have any ideas oh ya some times it will start up and run for like 5 minutes then die and wont restart. thx in advance for the help.
Old 09-07-2012, 09:47 PM
richphotos's Avatar
richphotos has a spectacular aura aboutrichphotos has a spectacular aura aboutrichphotos has a spectacular aura about
fuel filter?
Old 09-07-2012, 10:37 PM
tripwire401's Avatar
tripwire401 is on a distinguished road
I think rich is right. I ran into this very recently, mine was a pump and a filter tho. Gotta love cheap buys!
Old 09-08-2012, 01:04 AM
Rottidog's Avatar
What brand of pump did you use?
Search around in here. There have been a LOT of similar posts about start won't start, falls on it's face under acceleration, dies at lights etc.
Old 09-08-2012, 01:38 AM
4x4blazerguy's Avatar
If you didn't use a Delphi or AC Delco pump that is most likely your problem. But to be sure hook up a pressure tester & post the pressure when you turn on the key should be 60 psi. Then turn off the key & see what the pressure is after 5 minutes. It shouldn't drop more than 10 psi.
You should always install a new fuel filter with a new pump.
krzldy1949
08-19-2017 05:18 PM
barnesto
31
06-11-2014 07:12 PM
Chic_Bowdrie
18
05-12-2013 09:21 PM
outdoorxman
15
06-12-2007 05:06 PM
Inferno
10-22-2006 08:56 PM
Quick Reply: Blazer will start then wont start
