1997 Blazer engine stalling
Hi.
I have read all posts on engine stalling but I still haven't found solution to my problem.
When I start the car it runs fine at idle but when I push accelorator engine stalls. The biggest problem is that i have installed new MAF, new PCV valve, checked for vac leaks, installed new plugs, wires and rotor cap, installed new ignition coil, new ignition switch, cleand EGR valve, throtle body, IAC valve, checked the fuel pressure and nothing changed. I still have the same problem. So if somebody has an idea (no mater how stupid one) how to fix this please tell me becouse I'm feeling like .
I've read a lot here about replacing these parts with AC Delco. Stuff like your ignition coil, switch, rotor button and cap.
Try unplugging the new Mass Air Flow sensor your installed, fire it up and see what it does.
Edit: After searching some on the site
Also: You may want to look into a fuel pump relay. Also check the ground and voltage on the fuel pump with a multimeter.
jlw4049
12-24-2013 09:34 PM
20014x44.3
08-08-2012 04:40 PM
melissakaye
07-30-2012 04:04 AM
