Burn ecm1 fuse
Old 02-02-2013, 01:52 PM
juancdd's Avatar
juancdd is on a distinguished road
Default Burn ecm1 fuse
Hi, I have a 1998 LS Chevy Blazer LS, 4door, 2WD. I can't start it because it burn fuse ecm1. I have a short but where? I need some help!!!!!
Old 02-02-2013, 02:53 PM
PhilBilly's Avatar
PhilBilly is on a distinguished road
Oh boy, you're in for a project.
Finding shorts can be ridiculous.
First start from where its burning the fuse & trace them wires inch by inch. That includes all the connectors & pins. Look for splits, corrosion, anything out of the ordinary. Had the same problem w/ my Dakota. The fuse that supplied power to the diag connector under the dash kept popping. Of course everything of these older years are prone to corrosion & my problem was of no exception.
Secondly, it is possible but unlikely that you've got a power surge going on. Check to see if any other fuses are snapping.
Lastly, make sure you don't have any wires crossing or pinching.
I know this tip is vague but finding shorts will spin you into a dimension off pissed off you don't want. That is the way it is. Good Luck Buddy
Old 02-02-2013, 05:46 PM
juancdd's Avatar
Thank, I'll try to be patient. jejejejejeje
Brother Marc
07-05-2013 09:39 PM
mcmastrman
07-26-2012 06:10 AM
LagWagon
03-04-2011 07:43 AM
darkwarlord
10-20-2010 10:48 AM
mrhockey4real
19
08-17-2010 07:37 PM
Quick Reply: Burn ecm1 fuse
