Check Engine light P0107
Old 10-14-2008, 04:49 PM
ChicagoBlazer's Avatar
ChicagoBlazer is an unknown quantity at this point
Default Check Engine light P0107
This light came on for me a few days ago. Went to auto zone and got it checked out and they gave me this code. They listed like 4 reasons the code could be on.
1. Vacuum hose off, cracked, or passage blocked.
2.Throttle body intake tube loose, off, or cracked.
3. barometer / MAP defective
4. Vane Air Flow MAF sensor dirty or defective.
I have a 2000 blazer LT 4door. Just wondering if anyone knows for sure what it could be or how i can find out without having a mechanic charge me a crap load.
Also i have an emissions test this month. Does the "Guaranteed To Pass" emissions stuff work? Let me know. Thanks
Old 10-14-2008, 08:25 PM
Default RE: Check Engine light P0107
P0107 - Manifold Absolute Pressure [MAP] Sensor Circuit Low Voltage
I would start by testing the gray wire at the connector to the MAP sensor. This is the 5V reference wire from the PCM.
Old 10-14-2008, 09:54 PM
lol i forgot to mention i dont know really anything about engines except the basic stuff so trying to take anything apart would be suicide. but since you told me what the exact issue is i can at least go to my repair shop and tell them to check that out.
thanks for the info swart
Old 10-17-2008, 11:40 PM
ok a major symptom has arrived. is takes longer than normal to start it and sometimes sounds bad. any ideas ?
Old 10-18-2008, 08:13 AM
If you are not all that good at working on things, then you may want to attempt to just replace the MAP sensor itself. I do not like to give advice like this, but I also do not like it when people get taken advantage of by mechanics.
The map sensor is on the passenger side of the intake manifold and at most will require a small screw driver to aid in removing the electrical connection. The sensor itself just pushes into the plastic upper intake. You can get the sensor from pretty much anywhere. I am partial to AC Delco parts, but if you do not have a local retailer, the dealer would be the next place to get it ($$$).
It is not that expensive of a part ($30 when I had to replace mine on my old 2000 Bravada).
Old 10-18-2008, 06:41 PM
Alright man thanks for the help. I am very much appreciative.
Full_Out
01-23-2013 07:20 PM
ABSLT
01-24-2011 11:03 AM
bc4059
08-04-2010 08:36 PM
megtom2
12-06-2007 12:39 PM
Quick Reply: Check Engine light P0107
