When in doubt plug it in!!
Just a quick note in the dealings of DTC's:
In the last week my 2000 blazer has been popping quite a few dtcs (P0101,P0300 (the dreaded FI), P0404, P1410 i think) So i've been flipping out trying to chase the problem!! Tranny started missing the gears at 2100-2400rpm all the codes started popping up went out bought IAT sensor, TPS, cleaned CAI, and MAF (even bought a new on waiting for it). Hoping it wasn't the spider (it wasn't).
As luck would have it my truck wouldn't start after i reconected everything; The battery terminals were clean and tight, and still not making good contact ( mechanic buried the tabs into posts and back the screws out) leavin' 4 little holes in the contact and at that rpm would " rattle" causing an arcing situation.
So when you start having randoms codes, check your connections thouroughly may save you some head-aches.
Hope my headache helps someone else!
4.3l trouble
04-07-2019 06:54 PM
futuredoc
06-28-2010 02:50 PM
boulonman
03-05-2007 05:10 AM
2001Blazer4x4
03-02-2005 10:45 PM
