Dash lights on 95 blazer
Old 10-11-2010, 06:19 PM
dhvhrhmh's Avatar
dhvhrhmh is on a distinguished road
Default Dash lights on 95 blazer
I have check engine, brake,air bag, and anti-lock brakes lights on in my dash on my 95 Blazer. Is it true there is another code scanner that must be used for the anti-lock and air bag lights other than the OBD2 scanner? I also read somewhere that on 95 blazers there is either a 12 or 16 prong plug-in for OBD2 scanner. I just ordered a OBD2 code reader for my 2004 Buick and I should have it in a couple of days and was hopeing it would get out atleast 2 lights on blazer. Any information on this problem would be appreciated.
Dave
Old 10-11-2010, 09:26 PM
A generic scan tool will not be able to read the ABS & Airbag lights. Depending on what you get and what system you have in your truck (OBD1.5 or OBD2), you may or may not be able to pull the codes for the check engine light. If you have OBD1.5 and only want to read the OBD1 codes that may be stored, grounding a certain pin will work, it's just different on the OBD2 connector. There is a thread around here somewhere that states which pin to use.
Old 10-11-2010, 10:51 PM
zerepdivad's Avatar
zerepdivad is on a distinguished road
YOu may want to actually fix the problems instead of just clearing the codes...
mrspeedy69
05-23-2012 09:11 AM
new to chev
04-30-2012 09:03 PM
Steeltoe623
11-12-2011 03:10 PM
greendouglash
02-03-2011 05:13 AM
Aneurysm
13
05-03-2008 12:27 AM
Quick Reply: Dash lights on 95 blazer
