Fan only works on setting 4 then makes grinding noise after a couple of mins
Old 04-01-2012, 04:01 PM
dconnor.cfh's Avatar
dconnor.cfh is on a distinguished road
Default Fan only works on setting 4 then makes grinding noise after a couple of mins
Hey all I am new to the site but have found it very helpful already. Have an 01 blazer and the heater fan works on only the fourth or highest setting and then after a couple of minutes it makes a nasty grinding noise. It sounds like it coming from the glove box or around there. It does produce heat though. Any ideas would help.
Thanks
Old 04-01-2012, 06:22 PM
Old Skool Soldier's Avatar
Old Skool Soldier is on a distinguished road
Sounds like the resisters are blown on your fan. The resistors should be located in the heater duct passenger side, you'll have to remove and replace that
Old 04-02-2012, 01:04 AM
50lb_cat's Avatar
I agree it sounds like the blower motor resistor. There is a good write up of how to replace one in the DIY section of this forum. Not a very hard job.
Old 04-06-2012, 07:32 PM
Awesome thanks a ton for your help and that write up is amazing
Old 04-07-2012, 10:48 AM
If the motor is making grinding noises, the bushings are probably worn out. When this happens it causes amperage draw to increase, which is usually what burns out the blower motor resistor.
ezye1230
05-10-2015 10:14 AM
Saintsdad
06-06-2011 04:28 PM
jojocarreno
05-27-2011 12:27 PM
biglfla
01-06-2011 05:58 PM
offskooring
07-31-2009 07:59 PM
Quick Reply: Fan only works on setting 4 then makes grinding noise after a couple of mins
