driving lights don't work
Old 04-17-2009, 09:47 PM
robtheblazerowner's Avatar
robtheblazerowner is on a distinguished road
Default driving lights don't work
I'd appreciate help with my '99 Blazer 4 door 4WD. My driving lights quit working completely, however the brights work and the daytime running lights work. I checked the bulbs and ground, both ok. The light switch and the dimmer both are ok (I've already replaced the multifunction switch once).
The fuses are ok, I was wondering if there are any relays/circuit breakers I need to check. Or any other ideas?
thanks much, I rigged the brights into the driving light positions for a temp fix, but obviously this isn't ideal.
Rob
Old 04-18-2009, 03:16 AM
kiwiblazer's Avatar
Did you check the fuses in the BCM in the engine bay?
Old 04-18-2009, 01:03 PM
I'm not sure what BCM stands for, but I did check the fuses in the engine compartment fuse box, the two 15 A fuses there for the left and right headlamps were fine.
Old 04-19-2009, 06:58 PM
There is a relay for the low beams as well. It may be labeled HDM.
Old 04-20-2009, 01:27 PM
Default low beams return
Thanks for the suggestions:
My low beams started working again, with no help from me. When I disconnected the ground to the under hood fuse relay and then hooked it back up the low beams started working again. I noticed that the electrical systems, clock, etc had reset so I assume something in the BCM got reset.
Is this a reasonable explanation? Any ideas on why this happened?
thanks,
Rob
Old 04-20-2009, 05:36 PM
cage47's Avatar
cage47 is on a distinguished road
Possibly corrosion on the ground keeping it from making a good clean connection?
project85
01-15-2015 03:23 PM
96jimmyslt4x4
05-29-2011 03:55 PM
jojocarreno
06-12-2010 07:41 AM
Shamrock3
05-30-2007 01:58 PM
Quick Reply: driving lights don't work
