Front Differential
Front Differential
So I need to get a new front differential because mine has a crack in it. How do I check to make sure the gearing is the same on the new one so I don't destroy it while putting it into 4x4? Is there any markings or do I have to count teeth?
RE: Front Differential
ORIGINAL: Bauer318
1. Check the glovebox sticker that has the list of installed options then find a thread on the forum or another that lists the differential ratios...both front and rear will be the same.
2. Take your VIN# and either call Service Department at your local GM Dealer and they can tell you or you can physically go into the dealer and do the same...
Drew4711
10-06-2012 12:47 PM
98BlazerLT4x4
03-04-2008 06:00 PM
lilred67ddgt
12-07-2005 02:55 PM
