Clicking Behind Glove Box
thanks for you thoughts on the noisy flasher issue all, but my '98 is getting worse and worse after being replaced. The crazy clicking and buzzing seems to be affected by adding or dropping other loads like braking. One shop told me to replace a faulty signal stalk to cure it. Kind of pricey compared to a flasher!
Anyone know about this?
mrt
mrt
yeah most likely is the signal staulk (for your turn signals) they aren't that bad to replace. there was another thread on here. mine does the same thing. try slowly moving your staulk up and down and see if it changes. i read something somewhere where the the grease in there makes contact with the contacts and causes the noise of the turn signal to complete a circuit. i read it somewhere not saying its true. but i do know there was another thread discussing this same topic. also does the sound go away when you step on the brakes?
*really should post your question in a new thread, this was suppose to be closed awhile ago, what up kyle?
I would check out replacing the hazard switch and see if that cures your problem. For $15-20, it is worth a try. Check out the Tech Article (DIY) section for further information.
*Moved to a new thread*
And Spectre, best you leave the moderating to the staff of the forum. You do not need to comment on things, we'll get to it when we get to it. And if you must know, threads that were locked prior to the upgrade to vBulletin were no longer locked after the upgrade. Part of the transition. That is just how it is and no further comments should be made to that effect. Reply to the OPs questions and leave the rest to the staff.
Okay, Imma piggy back here. My mom has a 2001 Bravada, and when I started it, the flasher (I assume) clicked about 8 times, then stops. It didn't seem to effect any of the signal controls, or any lights. Why would it do this at start up? I know it shouldn't, but I didn't notice any other issues.
