HVAC auto climate contol unit
Old 12-15-2010, 06:48 AM
SSGuy's Avatar
SSGuy is on a distinguished road
Default HVAC auto climate contol unit
Hey folks
Been having (and still have) some issues with the A/C.
The dash control unit is working BUT the A/C button is just blinking three times and goes off.
The compressor doesn´t enable. The systems has been recharged. All fuses are ok. OBD2- Scan says "No A/C access".
Could the problem be a faulty computer climate control unit?
Has anyone ever had such a problem and/or knows a possible solution to my problem?
Thanks
Old 03-04-2011, 06:47 PM
Cayman Blazer's Avatar
Cayman Blazer is on a distinguished road
Hi SSGuy - I have the same issue, A/C, recycle and fresh air buttons all flash three times when pressed and then stay 'off'.
Reading other threads these are the checks that I've heard of...
The fan works AOK.
Have checked all the fuses (all OK).
Have removed the RDO Batt fuse for the prescribed 10 seconds and then set the ignition on for 40+ seconds for the ECC reset.
Still the problem persists!
We have replaced a failed battery recently, but can't confirm whether the issue is directly related, didn't notice the ECC issue until a while afterwards.
Grateful for some further things to check if you all know any!
thanks
Old 03-05-2011, 09:58 AM
Poh's Avatar
Poh
Poh is offline
Location: Berrien Springs, People's republic of Michiganistan, Socialist states of American
Poh is on a distinguished road
I was playing with it last night because I am also having issues with my computer climate control (you know, this feature actually works in my Lincoln) but what I cam up with is if you have defrost selected then the A/C won't come on and the light flashes 3 times. I set mine to panel and got the A/C to come on and also got the fresh air. hope that helps you or maybe you already thought of it.
if anybody can give me the solution to why everything on my computer climate control works as it should except that the temp control is stuck on max heat no matter where I set the temp, I will buy you a $5 foot long from subway ....... I will even include chips and a drink.
Old 03-06-2011, 02:19 PM
lfuller11's Avatar
lfuller11 is an unknown quantity at this point
It could be the electronic box that sits on top of the heater box behind the dash, or bad vacuum door actuator.
Old 03-07-2011, 12:36 PM
Thanks Poh - that worked to isolate the problem further - when the switch is set away from the position to defrost the windshield, the AC button will engage (well the light stays on now!). I'll be fiddling with the car tonight to see if I can find out about the continuing problem with the fresh air/recycle lights which still just flash three times!
Any other advice will be gratefully received...
Thanks all
Old 03-08-2011, 06:29 AM
Progress - of sorts!
When the switch is set to feet or face, all the settings work fine.
Recharged the AC last night with a hope of finding the leak and seeing whether the system decided to respond to some TLC. No cold air out of the vents yet though!
I could just revert to plan A - open the window instead of AC, but the window motor's on its last legs too...
So, time to start investigating the actuator I guess!
plumba
01-11-2013 04:36 PM
caprini83
04-12-2011 07:32 AM
002blazerdude
Lifting Tech
10-27-2010 09:43 AM
kota04sxt
12-10-2009 09:34 PM
zr2socal
04-02-2009 10:58 PM
Quick Reply: HVAC auto climate contol unit
