Keyless entry
Old 04-13-2008, 12:49 PM
Johnkoch's Avatar
Johnkoch is an unknown quantity at this point
Default Keyless entry
how do you tell if your vehicle came stock with keyless entry,is it the code au0, if it is i have it and will this remote work
eBay Remote
Old 04-13-2008, 01:54 PM
Default RE: Keyless entry
AU0 is the code for RKE. To know if that remote will work, you need to drop the lower hush panel on the driver side and have a look at the FCC number on the top of the module (located directly behind the DLC - data link connector). You need to match up the numbers (minus the R & T I believe which stands for Reciever and Transmitter respectively).
Fixed your long link too. You might also want to provide your vehicle information when asking questions of this nature. Putting that information in your signature and always attaching it to your posts will help out greatly!
Old 04-13-2008, 05:54 PM
Onimun is an unknown quantity at this point
I too am interestered in this. My 2002 Blazer doesn't have any remote with it but i think it bay have keyless entry. I know where the module is but whats the number i should be looking for? Thanks
Old 04-13-2008, 06:20 PM
It'll be on the label on the RKE module itself. The number you need to pay attention to is the FCC: ******** (unsure of the number of characters, but it's an alpha-numeric code).
Old 04-13-2008, 10:44 PM
Which Number says i have the Keyless entry and which one doesnt?
If i have the Code does that meen that i have keyless entry?
Old 04-14-2008, 07:36 AM
Did you miss it above??? The RPO code list inside your glove box shows all options originally installed on your vehicle. AU0 is the RPO code you need for factory installed RKE (remote keyless entry). If you do not have AU0, then you do not have RKE unless someone added it later on.
Old 04-14-2008, 12:26 PM
OK cool, ill look for it. Thanks.
Old 04-14-2008, 12:43 PM
Alright i just checked, i have AU3 not AU0, so thats a bummer.
bootsdsm
08-07-2008 09:45 AM
Whittaker
07-17-2007 08:00 PM
frankjc
04-26-2006 11:31 PM
93Miata
24
11-14-2005 10:09 PM
Thrty5thsc
15
06-28-2005 01:40 PM
Quick Reply: Keyless entry
