Metal brake line drivers side
Does anyone know the fitting sizes on the metal brake line that goes from the master cylinder to the rear brakes. I am buying some line wrenches and dont know if its metric or standard. Thanks
I replaced that line on mine last year, I'm 99% sure it was metric.
There is a location just behind the front wheel on the frame rail where you can tap into and I ran all the way to the back without having to remove anything large. I used bulk line and made my own flares because it was too long to use the pre-made pieces at the auto store. I also replaced the rubber hoses that cross over to the rear brakes while I'm there, I think they were pretty cheap from Rock Auto. Finally I replaced the two small lines on the rear wishbone, (from the flex line to the cylinder) and the line accross the rear axle to the other side. On mine it was all pretty rotten.
Jeff
Jeff
Xavier
04-11-2014 11:49 AM
blazinloud
24
10-01-2011 05:33 PM
jakegaisser
04-06-2011 11:35 PM
ESKYMOPACK
14
03-27-2009 09:42 AM
