Washer Fluid leaking
Old 12-08-2010, 12:39 PM
dacop's Avatar
dacop is an unknown quantity at this point
Default Washer Fluid leaking
So I went to add some washer fluid this morning and it all leaked out on the street. I looked under and couldnt see anything as there is a cover on the wheel base. I would assume this is some sort of hose problem? Can I get to it by removing the air filter cover just to the left of the washer fluid container?
Thanks!
Old 12-08-2010, 02:58 PM
AllenValk66's Avatar
AllenValk66 is on a distinguished road
I had a leak just like this; I pulled the air filter housing, and then removed the 1 nut that held down the w/washer bottle. There's 2 snap-on connectors for the washer pumps, and 2 hoses. Pull those off, then take the bottle out and fill with water. There you can find the leak. I had a lower washer pump/motor leaking. I bought a new one cheap enough from the autoparts store; it came with the washer pump rubber grommet and the pump too. I put it all back together with no leaks! It's not as hard as it might seem, once you have the air filter housing removed.
Old 12-08-2010, 08:02 PM
4x4blazerguy's Avatar
Have you checked to see if it is leaking under the rear carpet? I had a leak going to the rear washer.
Old 12-09-2010, 04:18 PM
helo's Avatar
helo is on a distinguished road
x2 leak in cabin going to rear washer. I cut my rear line in the engine bay and tied it in a few knots/kinks then taped it in place (rear wiper mechanism is frozen, anyway.. too lazy to fix it).
strange
12-24-2014 05:31 PM
4x4blazerguy
06-13-2012 10:22 PM
2000blazerdriver
11-03-2011 08:32 PM
fruccoman
02-15-2006 07:08 PM
Quick Reply: Washer Fluid leaking
