Starting Problems
Starting Problems
Having starting problems with 2000 Blazer. Installed new fuel pump and relay switch. Is not getting fuel into the throttle body. Can try for up to an hour before it starts. If I add a bit of fuel to the throttle body it starts right up and runs smoothly. Will a malfunctioning throttle positioning sensor cause this? Why does everything start working with fuel being added directly to the TB? Thank you.
cgrett
11-15-2010 09:08 PM
upblazer95
04-04-2009 08:27 PM
Sprocket
03-20-2008 09:39 PM
Dean S
01-30-2006 02:51 AM
