95 chevy blazer P0134
Old 04-27-2012, 04:15 PM
indianablue's Avatar
indianablue is on a distinguished road
Default 95 chevy blazer P0134
Hi, we need some help hubby replaced the plugs and wires on 95 Chevy Blazer, now the service engine light is blinking when you put it in drive, had code po134, but now no codes coming up, any ideas?
Old 04-27-2012, 04:20 PM
also i was told long time ago to not drive blazer if service engine light was flashing......is this true??
Old 04-27-2012, 05:35 PM
onebadsuv's Avatar
onebadsuv is on a distinguished road
Flashing service light indicates engine misfire which may damage emissions system so they flash the light - He probably got a plug wire mixed up on the wrong cylinder is all- so engine is misfiring
Old 04-27-2012, 08:30 PM
billfrank85's Avatar
billfrank85 is on a distinguished road
Don't continue to drive it with a blinking CEL. Fix the problem before serious engine damage occurs. Check all wires vs. firing order off the distributor cap. Make sure it's all bolted down properly.
Old 04-30-2012, 08:32 PM
thank you 2 very much, had to replace the distributer one of the little tips that hold a screw was broken and found #6 plug wire loose, Blazer is running AWESOME again. don't know who the brain was that thought up putting distributer at back of engine was. BUT WHO EVER IT WAS NEEDS SLAPPED UP SIDE THE HEAD LOL
poertsch
04-22-2014 07:05 AM
hlaverty06
03-05-2014 07:14 PM
ChevyMane808
04-05-2013 10:51 AM
beeneeb
12-07-2004 05:10 AM
Quick Reply: 95 chevy blazer P0134
