Rocker Arm Installation
Old 05-12-2011, 02:54 PM
benthm7's Avatar
benthm7 is on a distinguished road
Question Rocker Arm Installation
1998 Chevy Blazer LS, Install rocker arms and pushrods, torque rocker arm nut to 20 lbs to spec. but the pushrods are tight. Pushrods can not be turn back or forward is this right or wrong. Please let me know
Old 05-12-2011, 03:30 PM
If the lifter is off the base circle of the cam, there will be valve spring pressure on the lifter/rocker/push-rod. Perfectly normal. You can rotate the engine over checking each push rod as its lifter gets to the cam base circle and it should spin with some resistance.
monette999
04-12-2014 12:41 AM
benshuey
07-24-2011 09:53 PM
Cobra102000
02-03-2011 02:55 PM
ericthughes
10-19-2010 03:13 PM
stevelknievel
09-19-2007 08:54 AM
Quick Reply: Rocker Arm Installation
