94 s10 to a 96 blazer????
Old 08-08-2011, 06:19 PM
pfcboyce's Avatar
pfcboyce is on a distinguished road
Exclamation 94 s10 to a 96 blazer????
i am looking at a motor from a 94 s10 and looking to put it in my 96 blazer will it work and plug in to my computer it is a 4.3 vortec same thing i took out of my blazer
Old 08-08-2011, 06:22 PM
The two engines (CPI - 95 & older vs SCFI - 96 & newer) are very much different. The first major difference is in the fuel injection & intake. The second is in the ignition system. You really need to find a SCFI motor out of another 96 or newer truck.
Old 08-08-2011, 06:26 PM
pfcboyce's Avatar
so it will not work ??
Old 08-08-2011, 06:28 PM
If it doesn't have a CKP sensor, you'd have to find the parts to be able to add the CKP sensor. To get the fuel system to work, you would have to swap the heads & intake system over from your motor. And the timing cover, etc from your '96 motor won't fit on the '94 block. You'd only be using the long block and even that is different in a lot of ways. Do yourself a favor and find the proper motor. You'll save time & money in the long run over trying to make that '94 motor work in your truck.
So for summary and to answer your questions originally asked... NO, it won't plug into your truck and work with out significant and costly reconfiguring of parts that may or may not even work properly in the end. You can take a newer long block and use it in an older vehicle, but not really the other way around.
Old 08-08-2011, 06:31 PM
pfcboyce's Avatar
ok thanks
Dallas1970
02-22-2019 05:05 PM
94BlazerGirl
08-28-2014 06:14 PM
rfine67
08-13-2011 01:04 PM
ricky
07-22-2010 08:04 PM
1994BlazerS10
03-03-2010 08:52 AM
Quick Reply: 94 s10 to a 96 blazer????
